Audio affecting particle position
jooncult
Hey all I'm quite new to houdini so please bare with me.
Is there a way to use an audio output from chops to change the position of a particles?
Can I do that by using a pop vop? If  so, how can I import my chops output in there and add it to the position of my particles?
Is there maybe a better solution for that?
Thank you!
Absolutely.
It's a similar setup as I explain in this thread here:
There I'm moving the spheres, but you can, for example, control the offset of some noise inside a pop vop with it (or any other parameter). In fact, if you really just want to move the noise in a single parameter, you don't even need to bother with the copy chop, a single channel would be enough
Hey Vitor, thanx for the answer. I was wondering if there is a way to integrate it to my current setup. What I need is to figure out a way to add the chops output in my pop network instead of the popforce.
To be honest I dont really get yet the copy approach bu I will study it a bit and see if I can make it work.
Thanx!
curves.rar
