Q for the new boolean node
Hi, guys
   I`m  confused the new boolean node can not work with 2D geo in some times.
   Like deal with  a  grid node and curve node.
   I  creat a grid node modify the Rows and columns  50 by 100 , then  get  a  file node. The file node was a  bgeo file  which  created by curves nod.
   Use boolean  to  subtract B-A , but nothing happend.
   I holp some guys  can  fix  this
   Thanks  for help !!!
Boolean_test_v001.hip
If you look at the geometry spreadsheet of the file node, the Y component is not 0. So fix this by putting @P.y =0; into a wrangle, and treating both Set of inputs as Surface not Solid from the drop down menu on the boolean.
Edited by Cybernetix
Thank you so much Tim,it works great!
