art3mis
Redshift users, post your tips tricks here please!
Ok, so not a whole lot of Houdini Love over on the Redshift forums. Mostly Maya, 3dmax, C4D (in that order)
https://www.redshift3d.com/forums/viewthread/10860/
Hence the reason for my posting here.
Anyone care to share any Redshift tips, tricks and tutorials specific to Houdini users?
Here is one great tip that Adrian from Redshift  was kind enough to share for customizing RS Spot lights
https://www.redshift3d.com/forums/viewthread/12283/#79060
Share this post
Link to post
Here is a Python script I wrote, Images As Planes, that reads in images in a folder and creates Redshift Materials with texture maps for each image in the folder. If you are looking into creating materials for Redshift, via python, consider this example code.
Here is a procedural planet rendered in Redshift. It routes VEX/VOP generated noise attributes to Redshift materials.
ap_rs_procedural_planet_050517.hiplc
Edited by Atom
  • Like 3
Share this post
Link to post
Create a Redshift SpotLight, unlock the HDA and then use the Jump button to jump into the Redshift light shader. From there you can connect a rsTexture to the color input of the light to project an image as the light.(i.e. light gobo)
ap_rs_spotlight_gobo.hiplc
If you enable Volumetric on the Redshift ROP and set the Volume Contribution value for the Spotlight greater than 0, you get a volumetric light.
ap_rs_spotlight_gobo_volumetric.hiplc
Edited by Atom
  • Like 4
Share this post
Link to post
Here is a Redshift instancing ground cover setup. The meshes included come from cc0 sources. This mesh set contains grass and spring time plants but the system can scatter any mesh set across the target surface. (i.e. rocks, trees, plants etc...)
This scene uses the image based volumetric spotlight to achieve colorization.Untitled-1.jpg
ap_rs_instance_ground_cover_050517.hiplc
Edited by Atom
  • Like 2
  • Thanks 1
Share this post
Link to post
I have been working with rendering volumes in Redshift. As I render more objects as volumes I kept coming back to this one setup. I thought I'd post a screen shot.
Share this post
Link to post
Here is a blood cell flowing inside a blood vessel. The cells move along a path to form the blood stream. The blood vessel itself is also generated from the path.
ap_rs_blood_cell_080417.hiplc
Edited by Atom
Share this post
Link to post
i have redshift installed but i dont like to use it :P   i feel like im in maya with one click solution, i like the hard way,  the way of the cowboy,  i will stick with mantra :P
Share this post
Link to post
Yeah, sometimes I like to watch paint dry too.:huh: (especially when I'm paid by the hour)
Here is an example scene that demonstrates lighting with only material emission. There are no lights in this scene. The shader uses a RaySwitch to decouple material based emission from incandescent emission. This allows you to overdrive incandescent output while not blowing out your diffuse. You can even choose an alternate color for the incandescent light as shown in this scene. The sphere emits RED but the incandescent emits BLUE.
ap_rs_light_by_material.hiplc
Edited by Atom
  • Like 4
Share this post
Link to post
Is there a way to render my backplate in Houdini's render view?  I Maya it works with the RSLightDome but not in Houdini's render view or redshift's render view.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
