Create geometry with AttribWrangle
ryreh
Hello! Sory for my English
I'm trying create geometry with AttribWrangle node in Detail mode. I use addpoint, addvertex and addprim nodes. When I created some points how could I get access to them into the node?
For example, I created point pnt0 = {0,0,0,}. And now I want to create point pnt1 which is close to pnt0:
int X = 3;
int pnt0 = addpoint(0, set(0,0,0));
int pnt1 = addpoint(0, set());  - and here I want to get position of the first point and add X to each coordinates.
Is it possible?
Edited by ryreh
you could do something like this
float x = 3.;
vector pos = {0, 0, 0};
int numPoints = 3;
for(int i=0; i<numPoints; i++){
    addpoint(0, pos);
    pos.x += x;
    pos.y += x;
    pos.z += x;
but if you don't want to generate your points in a loop you could do something like this
float x = 3.;
int pt0 = addpoint(0, {0,0,0});
vector pos = point(0, "P", pt0);
pos.x += x;
pos.y += x;
pos.z += x;
int pt1 = addpoint(0, pos);
Edited by holycause
