"caching" VEX Code?
Hey peeps,
Is there any chance to cache or to increase the performance of an VolumeWrangle node?
I know, how i can do it with dopnetworks, but i have no clue HOW TO for that VEXnode...
cheers natnat
Hello Attila. You may use the File Cache SOP node anywhere to cache your results. Or the Cache SOP node, also anywhere.
As regards the performance, it depends what are you calculating. You may consider using the VDB and also many VDB nodes are amazingly fast (VDB Smooth, VDB Analysis), some of them accept Mask as a second input, which is also useful. Dig through the docs http://www.sidefx.com/docs/houdini/nodes/sop/vdb
