Welcome to od|forum
Register now to gain access to all of our features. Once registered and logged in, you will be able to contribute to this site by submitting your own content or replying to existing content. You'll be able to customize your profile, receive reputation points as a reward for submitting content, while also communicating with other members via your own private inbox, plus much more! This message will be removed once you have signed in.
Sign in to follow this
Followers 0
garf
hou.pasteNodesFromClipboard()
Anyone know how houdini decides where to paste these in the network view? They often end up pasted miles away from the working area.....
Share this post
Link to post
The network editor has a local coordinate system (X and Y locations). My guess is that by default the nodes get pasted at (0, 0). If the pasted nodes are going to be wired into existing setups, you can always try hooking up the inputs and using Node.moveToGoodPosition() or Node.layoutChildren() on the pasted nodes. Alternatively, you can query the location of one of the existing nodes (probably the last node in the branch) and use hou.moveNodesTo() to move them close to that location.
Share this post
Link to post
I'm not convinced they are pasted to 0,0 ideally I'd like to lookup where in the coordinate system the network viewer is currently showing and just bung them somewhere in there. I'm liking the moveNodesTo() idea though - I might give that a go
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Followers 0
