Welcome to od|forum
Register now to gain access to all of our features. Once registered and logged in, you will be able to contribute to this site by submitting your own content or replying to existing content. You'll be able to customize your profile, receive reputation points as a reward for submitting content, while also communicating with other members via your own private inbox, plus much more! This message will be removed once you have signed in.
Sign in to follow this
Followers 0
jackassol
FEM / CLOTH - Target GEO
Hello guys,
I have a cloth object and addet a target object in the DOP Network.
Is it possible to control the transformation to the target-object ( Target Stiffness) with a animated noise?
Best ;-)
Share this post
Link to post
If you add a float point attribute to your target mesh named "targetstrength" (as its now called) it will act as a multiplier to the target strength parameter. This is true for most of the cloth object parameters.
1 person likes this
Share this post
Link to post
If you use a multisolver node, you can affect your cloth object with both a cloth solver and a sop solver. In the sop solver you can process your cloth mesh any way you want, in your case adding animated noise to the "targetstrength" attribute. See attached for an example of how you might set this up.
animated_cloth_noise.hipnc
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Followers 0
