A question on mestela's CHOPS Sequential Anim setup
Hi :)
I've been studying mestela's CHOPS setup, the link to which is wight below:
I'm intrigued by his setup but for the life of me just couldn't figure out what to do in the Chopnet to overlap the animation on the sequenced pieces at a certain amount... Any ideas?
Thanx in advance :)
Cheers;
AJ
Had a play, I think this method is cleaner than that other setup.
Sticking with the same idea (driving a poly extrude with @zscale, and wanting to both animate and stagger that attribute), this setup has 2 methods:
1. Drive zscale with a wrangle, keyframe all the points/prims identically, and use chops to stagger those keyframes for each point
2. Make the animation wave in chops, and use 2 math chops to create as many blank channels as you require, then copy the animation to each channel, then stagger as before.
chops_repeat_anim.hipnc
