Welcome to od|forum
Register now to gain access to all of our features. Once registered and logged in, you will be able to contribute to this site by submitting your own content or replying to existing content. You'll be able to customize your profile, receive reputation points as a reward for submitting content, while also communicating with other members via your own private inbox, plus much more! This message will be removed once you have signed in.
defc0n1
Global variable using python
Hi guys
Can you set global variables using python within an HDA? I have an ordered menu that is being populated by a python menu script. Is it possible to set a global variable from in there?
Thanks!
Share this post
Link to post
Never tried it but it should work. After creating the variable call global like this.
foo = 25
global foo
Share this post
Link to post
foo = 25
global foo
Hi Luke
Doesn't seem to work - SyntaxWarning: name 'foo' is assigned to before global declaration :(
Share this post
Link to post
Try fetching the global from within a def.
foo = 25
def multFoo(passedMult):
    global foo
    return foo * passedMult
Edited by Atom
Share this post
Link to post
Depends on what are you trying to achieve.
1. If you wanted to store something per node , with the possibility to keep the info in the hip file.
2. hou.session module, where you can store and share Python objects within the current session of Houdini.
3. HOM shortcuts to modify the current environment variables: hou.getenv(), hou.putenv() and hou.unsetenv()
It will be available for use in parameters as $MYVARNAME until you close Houdini. It will not appear in the Aliases and Variables window, however.
4. If you really want to modify HDA definition globally, you can add a Section and save definition after that.
It will be available in the Extra Files tab of the Operator Type Properties window.
Share this post
Link to post
Thanks for the help guys. I managed to do what I wanted by just passing around some detail attributes. Seemed much simpler!
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
