OpenCL simulations on ADM GPU
kiaspid
hi guys, sorry can't speak English well. I planning to buy new hardware for OpenCL simulations on GPU. I study a little about pro-GPUs computing performance and find some information in https://en.wikipedia.org/wiki/FLOPS "Built using commercially available parts. AMD Ryzen 7 1700 CPU combined with AMD Radeon Vega FE cards in CrossFire tops out at over 50 TFLOPS (OMGOD!!!) at just under US$3,000 for the complete system." is it right? Can combine two AMD Radeon Vega FE cards in CrossFire with CPU? Does it help to speed up simulations in Houdini?
Which Single-precision or Double-precision floating-point is more important in Houdini? is it depend on 32bit or 64bit process in software?
https://pro.radeon.com/en-us/product/radeon-vega-frontier-edition/
OpenCL™ 2.0 Support
Enables professionals to tap into the parallel computing power of modern GPUs and multi-core CPUs to accelerate compute-intensive tasks in leading CAD/CAM/CAE and Media & Entertainment applications that support OpenCL.
Does Houdini support OpenCL 2ver?
Edited by kiaspid
that's only possible for fp16, Houdini uses more precision with fp32+
Since almost five years, Houdini only support 64 bit platforms:
https://www.sidefx.com/forum/topic/27117/
About Single Precision or Double Precision, it depends on what kind of data you want to store. For example, in the FBX import doc, it is specified that some vex datas can be single or double precision. http://www.sidefx.com/docs/houdini/commands/fbximport
Maybe this other page of the doc will help you, it explains that you can changes the precision and amount of memory used to store an attribute. Warning:  Not all operations in Houdini maintain 64-bit precision.
http://www.sidefx.com/docs/houdini/nodes/sop/attribcast
Edited by dudenay
For OpenCL sims, single-precision is most important - double is used as an accumulation buffer to help avoid rounding errors afaik. This may be different for the OpenCL SOP.
