Boolean doesn't work after Convert VDB (polygons)
alex333d
it's same problem as this:
basically, the Prim Normals aren't consistent and that confuses Boolean...haven't found a solution to your setup yet but I'm quite sure the Prim Normals have to be 'unified' first...(if you put Reverse after your convertVDB and quickly flip flop it, you'd see there's some potential clues around the ears)
here's a workaround using VDB (not volume)...you lose a bit of fidelity...I don't know enough about VDB 'reshaping' to regain its orig shape...others might...
(no I'm not 'intelligently' solving this problem...just brute force)
hmm..just noticed it has a 'shell' effect...interesting...
VDB_SDF_boolean.hipnc
Edited by Noobini
  • 3 weeks later...
