Rendering clouds with the "Sky Rig" shelf tool with Redshift
mz2
I can't figure out how to get the output created by the "Sky Rig" shelf tool from the Cloud FX shelf to render with Redshift. I have no similar issue with the volume created by the "Cloud Rig" tool, although both seem to me like they create a VDB volume with a channel called "density" (which is what I've tried to render in Redshift with an "RS Volume" shader, which again works just fine with the kind of volume that "Cloud Rig" creates). What am I missing?
  • 1 month later...
On 11/6/2017 at 11:06 PM, Sepu said:
yep just connect the Render flag to your volume here is a quick example and make sure that you have a light contributing the volume as well as having the obj properties enable and having volume turn on.
SkyCloud.hip
thank you sir for the HIP file, you rock
