BludArtworks
Texture baking issue
Hello !
I'm learning houdini and tries to bake a simple position make texture using either the bake texture rop or the game baker shelf tool. Either way I get both error when rendering to disk.
I'm using pighead geometry . Everything goes just fine when rendering to Mplay strangely.
Here are the errors I get :
Baketexture ROP :
Error
Command Exit Code: 1
[15:36:16] mantra: Mantra tile imager open failure: Tiled Image File: 0 file []
File: C:/temp/H16TextureBake/test.tga
[15:36:16] mantra: Could not open imager
[15:36:16] mantra: UV rendering failed for object /obj/geo1
Using rop_game_baker
Error
Error rendering child: /out/rop_games_baker1/baketexture
Error
Error rendering child: /out/rop_games_baker1/pre_bake0
Does anybody have clues about it ?
Where I could get more information about texture baking ?
PS : I'm using Houdini apprentice
Edited by BludArtworks
Share this post
Link to post
Guest Sooi
Just found out that the Houdini Apprentice render resolution is limited to somewhere around 512x512.
Anything up to that resolution should render just fine.
Share this post
Link to post
You are commenting as a guest. If you have an account, please sign in.
  Only 75 emoticons maximum are allowed.
