bakeTexture SurfaceColor(cf)
don't bake Cf. pipe surface color into arbitrary channel and render that as a custom image plane. predefined channels never work for me when baking (or maybe i just did not understood how it's supposed to be used)
unfortunately there is no straightforward way. you would have to build it again in SOPs or render the texture and use it as a source for point colors. theoretically you can copy an paste nodes from mat net to VOP SOP but that generaly doesn' t work well. shame .-/ other way around - from SOP to shader it's very easy thou just by reading geometry attributes.
