The question about HQueue
I would like to ask a question about Houdini HQueue. My Shared directory is my C disk. The remaining space of it only has more than 100G. When I make the large  simulation, the cache is also very large. The remaining space isn't enough. May I know how could other computer read my other disk, whether I need re-install HQueue Server? Or do you have other solution except change a larger hard dive.
You’ll need to point it at a drive that has sufficient space; if you don’t have a larger D:/ drive, or other drive, you’ll need to add a large hard drive and change your server to point to that. I’m not very familiar with HQueue under Windows, but this link for editing the shared folder should get you started: http://www.sidefx.com/docs/hqueue16.0/help/faqs#how-do-i-register-a-shared-folder-with-the-hqueue-server
Hope that helps!
