COPS memory leak
guache
I have a COPS setup of ~25 nodes. I'm trying to comp a sequence of about 10,000 frames and I see a memory leak. Every frame adds about 20MB to used RAM. Given the length of the sequence, I keep running out of RAM. Is there a way around it, e.g. some kind of a COPS node that frees up memory or some other workaround? In Compositing Settings, I've already lowered the max comp resolution to the minimum I need, and the bit depth to the acceptable minimum (8-bit) but the leak is still here.
Win 7 x64, Houdini 16
Edited by guache
