Fluid Compress Crazy Behavoir!!
thelonium
Hi!
I have a FLIP SIM (about 40M part), with a tank and a geometry emmiter. Everything works fine in DOPs.
When I import the SIM to SOPs I apply a Fluid Compress node. Then I see extrange behavoir of the surface volume, just after it's treated by the Fluid Compress node (before this node the surface volume was ok). Now apear random boxes around the liquid.
Here you have a flipbook of the surface volume with problem:
If I desactivate limit Bandwidth from Fluid Compress node, the the surfacing node get error.
How can I fix this?
Thanx!!!!
