skyros
Switching Views using python/hscript
I'm in the middle of making an otl for our artists and was wondering if there is a way to switch Houdini's viewport panes between Scene View and Composite View.  I haven't found the proper help files for manipulating Houdini's layout through scripting.
Thanks
Mike
Share this post
Link to post
You'll need to iterate through the pane tabs in the current desktop to find one whose type is SceneViewer, then:
hou.curDesktop().paneTabs()[ index_of_viewort_tab ].setType( hou.CompositorViewer)
Share this post
Link to post
Thanks for the heads up Mark.  That was enough for me to search around a little more in the help files.
I have to say I found referencing UI elements a bit confusing since there seem to be several ways to look up different elements.  I ended up changing 'setType' to 'setIsCurrentTab', since I didn't want to actually change the tab but rather which one was selected.  If you have some thoughts on how I could improve this I would appreciate it.
import hou
class TabSwitch:
    Switch viewport tabs based on user input
    def __init__(self):
        self.comp       = hou.paneTabType.CompositorViewer
        self.scene      = hou.paneTabType.SceneViewer
    def getTab(self, tab):
        paneTabs = hou.ui.paneTabs()
        for pt in paneTabs:
            if(pt.type() == tab):
                pt.setIsCurrentTab()
ts = TabSwitch()
ts.getTab(ts.comp)
Edited by skyros
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
