Houdini Expression Editor plugin
Cetras
Hey Guys
I wanted to share with you a small script I've done to have a better support or external editors to edit your expressions and code. It works with a system or file watcher, that means it doesn't freeze Houdini and you don't need to close your editor to see you updates :) It's available by a simple right-click on a parameter => expression => External Expression Editor ( you can set a hotkey ).
It works with VEX and Python expressions but also regular HScript expressions ( but with no completion ). It works very well with Visual Studio Code as it has a nice VEX and Python plugins, but it could work with sublime text, notepad ++ etc.
( I haven't tested all the IDE out there so if you find a bug with one of them, feel free to send an email to contact@cgtoolbox.com ).
A small video about it:
You can download it for free here:
PySide, PySide2 and PyQt are supported, it is compatible with Houdini 15 to 16.5.
  • Like 6
Looks simple and bug-free. With some small additions, this system could work in both directions: file changed? Update parameter. Parameter changed? Update file. File changed when user still typed his parameter? Prompt user about merging. Maybe even cook nodes and output node errors to some companion files?
That should be implemented natively in Houdini and replace existing system, because it is so clearly better than blocking process. Houdini already use temporary files for external editing. Modern editors track files themselves very well.
This is really nice! Thanks. I wish i could tie this directly to "Edit Expression" though, instead of having to rely on the "External Expression Editor" command. Having a keyboard shortcut on the "External Expression Editor" is kind of limited (not your fault) as you have to either select or hoover over the "VEXpression" parameter label for the shortcut to work. Whereas the "Edit Expression" shortcut fires if you have the cursor in the snippet field. Would be even better if you could just select the node in the editor and fire of "External Expression Editor" from there. Again, not your fault :)
-b
Great thanks a lot.
-b
This should be doable no ? I'll look into the code
  • Like 2
  • 3 months later...
  • 3 weeks later...
I watched that section :)
At 17:17 varomix as a, what appears like an absolute path within his HOUDINI_PATH variable, even though I know he's using Linux. In my case I have an absolute path to the plugin for HOUDINI_PATH and I didn't forget at the end the semi-colon and ampersand characters. Although when restarting Houdini, I see no Set External Expressions Editor from Edit > Preferences within Houdini ?
  • 3 months later...
Hello my friend. Your plugin works perfectly with vex and python. Good job!
As default, in a pointWrangle Node,  ALT + E calls out an advanced editing window straightly when cursor is in the code area.
 I have set a hotkey(such as ALE + R) for calling out my VS Code panel. It works but it's slightly different from the ALT + E combo. I need to right click my mouse in the code area => move mouse to the "Expression" => ALE + R.
Could you please optimize the workflow?
Plus: My English is not good but I hope you could understand what I mean. : )
  • 3 weeks later...
I'm having the same issue. I have to actually install the plugin's files in my Houdini's home path. I'd like to keep that path clean and instead add a custom path to HOUDINI_PATH. I've done this, but it doesn't pick up the script.
That's weird, here I have this on my houdini.env:
HOUDINI_PYTHON_TOOLS=/home/guillaume/Documents/__dev__/HoudiniPythonTools
HOUDINI_PATH=$HOUDINI_PYTHON_TOOLS/HelpCardMaker:
HOUDINI_PATH=$HOUDINI_PATH$HOUDINI_PYTHON_TOOLS/HoudiniEasyCompileBlock:
HOUDINI_PATH=$HOUDINI_PATH$HOUDINI_PYTHON_TOOLS/HoudiniExprEditor:
HOUDINI_PATH=$HOUDINI_PATH$HOUDINI_PYTHON_TOOLS/HouGitHub:
HOUDINI_PATH=$HOUDINI_PATH$HOUDINI_PYTHON_TOOLS/Houpy_PyTakes2:
HOUDINI_PATH=$HOUDINI_PATH:&:
And it works fine ... For the shortcut issue I haven't found a solution so far :(
( on ubuntu, but same thing on windows but with ';' instead of ';' )
  • 3 months later...
