[SOLVED] Grains > replace geo
caskal
Hey magicians,
Been fighting with this pile setup for a couple of days, I need to make a candy pile, I'm using grains but when I replace the geo there are some artifacts like the geo is inside the particle and leaves weird holes, anyone knows how this can be fixed? It need to be the more realistic way possible
@f1480187 would love to hear your thoughts sensei
Thanks
pile3.hip
Edited by caskal
The holes/gaps are caused because you are copying a sphere to points after the simulation then scaling the sphere into an ellipse/pill shape.
A better approach is to shape your geometry first then submit that geometry for true collision testing. Then you will get a gap-free pile.
ap_M&M_drop_into_jar.hiplc
You saved my day!, this is exactly what I was trying to achieve, thanks a lot @Atom
Played a bit with @Atom setup, main issue was houdini getting slower at high frames so I made a proxy to collide (pile at the end will be static thankfully)
P.S: How can I stop emiting geo at certain frame? I tried $FF < 200 at rbdpackedobject creation frame with no luck, maybe in the sop solver?
P.S 2: I'll export this to cinema 4d to render, how can I export to texture each candy in say 5 colors with a logo on it? adding a uv texture sop?
Cheers!
Edited by caskal
add an enabled solver
$SF<=200
About exporting to C4D, you can export UVs and do the shading in C4D. But not 100% sure how C4D will handle it. I know that they added color vertex in 19 so you could look into that as well.
Edited by Sepu
$SF<=200
could you explain this please, doesn't this stop EVERYTHING ? ie. a falling piece stops dead in midair ?
Edit: must be me...after reset sim...all is fine
Edited by Noobini
