Volume Visualization Plane Shifting [solved]
evanrudefx
Hey!
Is this normal behavior? I am trying to visualize the velocity field of my pyro simulation, but the position of the plane on the y axis keeps shifting up and down which makes some frames look completely different because it is looking at a different y position of the sim. It makes it difficult to see if my velocity field is simulating correctly. Look at the two photos below, it seems like the velocity drastically changed, but its actually because the slice moved upwards and it is showing the velocity of a higher part of the sim. Is this normal?
Thanks
Edited by ejr32123
