install redshift in houdini
Look like this:
# Houdini Environment Settings
# The contents of this file are read into the environment
# at startup.  They will override any existing entries in
# the environment.
# The syntax is one entry per line as follows:
#    VAR = VALUE
# Values may be quoted
#    VAR = "VALUE"
# Values may be empty
#    VAR =
# Example:
# HOUDINI_NO_SPLASH = 1
HOUDINI_DSO_ERROR = 2<font></font>
PATH = "C:/ProgramData/Redshift/bin;$PATH"<font></font>
HOUDINI_PATH = "C:/ProgramData/Redshift/Plugins/Houdini/16.0.705;&"
