difference between @Cd.r and $CR
PhiiLL
Dollar variables are hscript expression variables, hscript is sloooowly being phased out.
At-symbols are vex attributes (@-ttributes, get it?), they're becoming the standard way to refer to geometry properties through most of houdini, its better to get used to that syntax.
Occasionally you'll find some older nodes that only work with the older dollar syntax, best to ask here if you stumble across those. :)
-matt
-matt
Thank you for the quick answer :)
I was trying to scatter points based on color, but when I set @Cd.r as density within the scatter node, I get an error :/
And that's another fun gotcha with houdini; if something is designed to read attributes directly (like the scatter sop is), you don't use the @ prefix.
That also means that it won't understand the thing.subthing syntax, so Cd.r won't work either.
Put down a point wrangle before the scatter, and create a new attribute which is just the red component, we'll call it red:
@red = @Cd.r;
Now in the scatter you can put 'red' into the density attribute field.
It'll make sense in time, honestly!
  • Like 2
@red = @Cd.r;
so in this case its easier to use $CR than putting writing a new attribute and then putting that into the scatter :P
scratch that.. I bow before you matt :P
Edited by Jesper Rahlff
  • 3 years later...
@red = @Cd.r;
Thank you, Matt! Finally, I've got this thing.
