How to import obj with python?
Bakiki
I'm trying to script a multiple obj importer, could someone tell me how to do a basic obj importer equivalent to the "File" SOP...
Here's what I have so far....
node = hou.pwd()
geo = node.geometry()
import os
import numpy as np
folder = r"PATH TO FOLDER WITH OBJ's "
models =  [f for f in os.listdir(folder) if f.endswith('.obj')]
rand = np.random.randint(0,len(models))
path =os.path.join(folder, models[rand])
print os.path.join(folder, models[rand])
obj = hou.node(path)
obj.createNode("geo")
I made a python script similar to what you are trying to do.
Feel free to check out the code here. It might have some tips on how to make nodes and populate their parameters. It basically uses the existing File node, created by default when a geometry type object is created, to read natively supported mesh/object types.
If you are looking to create and manage a non-native 3D object type. Take a look at my moon scanner script. It reads NASA data and constructs a geometry mesh from that data.
Edited by Atom
the simplest approach is to use a packed disk primitive.  create a pakedPrim for each file you wish to read, then stuff in the path using a primintrinsic.
http://www.sidefx.com/docs/houdini/hom/hou/PackedPrim.html
you can unpack later to turn into geo, or if you don't need to process anything, just leave them as-is for better performance for rendering and display.
if you need a format unsupported by houdini, then you've got a different problem on your hands.
