Sign in to follow this
leroyjenkins3000
Alembic output to C4D flashes random squares in geometry?
Getting random flashes of rectangle geometry after rendering Alembic sequence to disk from Houdini 16.5, see below:
Would it help to share all of my FLIP, fluid particle, static object node attributes or is this a familiar problem people have run into before?
Share this post
Link to post
I have seen those kinds of noise based surfacing occur in Houdini. It may not be related to Alembic export.
What do you see on that frame when you inspect the FLIP sim in Houdini?
Share this post
Link to post
As far as I know there are no static objects there to give a collision of any sort?
Share this post
Link to post
Look at your surface, not your particles, inside of Houdini.
Share this post
Link to post
Wow, there you go. I'm still a Houdini noob but remembered which node to click to see the mesh. Simulation was tweaked a bit but there it is. It weirdly sort of looks like my emitter in an odd way...
Emitter is a rectangle with some noise stuff applied to the particle generation.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
