How to scale linearly with Sop Solver?
Hello guys!
I have a math problem, i need scale circles with sop solver, but i need scales linearly, but for each iteraction (frame) scaling acts exponentially.
i tried use some formulation on transform inside sop solver with “log()” but with no sucess…
what i need is circles scaling equidistantly, so i need some trick to scale linearly.
and yes, need reside inside a sop solver.
any ideas?
attached a image showing above the problem, and below (manually made) what i need output…
thanks in advance.
Edited by rod.vfx.td
2 hours ago, Gorrod said:
maybe try this out
scale_circle.hipnc
thanks, very interesting solution! but how to scale only in x and z? i tried modify your settings, but the result was a cross, not a circle...
scaling in xyz, result incoming geometry (a oscillating waveform circle) turn an sphere... i need only a concentric circles (x and z scaling).
again, thanks in advance! :)
3 hours ago, Noobini said:
try this ?
LinearRings.hipnc
(note that it could have been easily done with just a polyextrude>inset>divisions....but I guess you have reason to use a solver SOP instead so I tried solver SOP)
thanks! but for my user case i can't use polyextrude inset, i really need scale lineraly the incoming geometry... (a oscillating waveform circle)
