packed disk sequence files warp attrib
My question is about packed disk sequence files. The docs state:
Packed disk primitives automatically cycle when the rendered frame is outside the animation’s frame range. You can change this by setting the primitive string attribute "wrap" on the packed disk sequence to one of "clamp", "cycle", "mirror" or "strict".
I assumed the meant you could add a sting attrib named wrap with the value of mirror to the primitives of cached geo and this would cause the file node to play back the PDS files back in a ping pong cycle. however this didn't work. what am i missing?
  • 2 weeks later...
