miccetro
Rigging a ribbon type setup (Rotation trouble)
Hello peeps, I'm trying to figure out something similar to some sort of ribbon setup in Houdini. Still, lots to do but right now I'm trying to work out rotations, I have twist working by itself such that if I twist the ribbon the bone rotates accordingly and bend working by itself as well, however, if I twist and bend the ribbon at the same time, the rotations become unstable. How can I fix this? Any help is much appreciated!!! Thanks.
ribbon_setup_test_01.hip
Edited by miccetro
Share this post
Link to post
So I've realized that the rivet object has some attributes to create a coordinate frame (see attached), so I've used the cross product to build one using normal of the ribbon. But I still have flipping created by the cross product. Is there a way to solve this? or could someone point me in a better direction to build a ribbon spine type setup in Houdini? Thanks.
ribbon_setup_test_03.hip
Share this post
Link to post
Another update on this. I Think I've found a setup that works using the sticky object on merged individual NURBS patches, maybe there is an easier way to set this up manually. But check out the attached file and feel free to give some feedback on this. Thanks. (You can turn persistent handles “ON” on the bones or dummy boxes to see axis handles)
ribbon_setup_test_04.hip
Share this post
Link to post
I tried it but i don't which one is control, because only the null(controller) can move something.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
