Hello fellow odforce-people,
at the moment I'm working on my bachelor thesis which I'm writing about Dynamic Simulations for Film in Houdini. In order to demonstrate these effects, I'm producing two shots of a short film that I've wanted to do for a long time. And for the environment of this short film I decided to do some procedural modelling with Houdini. And since the houdini community is so extremely generous, I decided to take part myself and share my entire project file. It's slightly messy, but I hope it's useful. :)
* I started out in Cinema 4D where I did some basic cloner-modelling to get all the basic shapes right.
* Then I moved into Houdini, converted everything to an SDF and cut out dynamically generated holes.
(Scatted loads of spheres into a vdb that I generated from the sdf, displaced the spheres, made an sdf from it and "difference-d" it away from the main mesh.)
* Having converted the object back to polygons, I ran the mesh through Instantmeshes to get a clean quad-mesh. (Love this program almost as much as Houdini.)
* For uv-mapping and memory-efficient exporting I got rid of all the faces that were not visible from the inside. (more than half)
(I wrote a little script that sends rays from every point of the mesh to the 'god-points' in the center (because godrays, haha... ha...) and when any of these rays hit, it's marked as visible (green). Then I get rid of all the invisble points (red).
* I unwrapped the mesh using Auto-Unwrap from the game-dev-toolkit and exported it (as well as the high-res-version from before) to Substance Painter where I baked all the maps (normals, AO, etc.) from the hi-res mesh to the low-res mesh.
* In painter I just smashed a couple of smart material on there that I found on Substance Share, scaled up the UV-Tiling (because huge mesh) and was pretty much done with texturing. The render is a screenshot from painter's integration of I-Ray.
(When I get everything together in Cinema and render with Octane, I'm gonna step the lighting up a notch of course. ;))
Here's a couple of pics:
Arena_TexRender.thumb.jpg.53213b26c3d9c7a020e68dc3e996eef9.jpgArenaWrangleV55.thumb.JPG.3dbf3bd20df58f05a448587c791bc0c5.JPG20180414_0039322.thumb.jpg.285fdab681e6599f2b919992c1fd074e.jpg5ad5c7ad61103_WhatsAppImage2018-04-17at09_59_07.thumb.jpeg.9b91319f983aad677e038c6f1724664f.jpeg
And attached you'll find the project file as well as the base-obj I started out with from Cinema (And one remesh to work with in case you don't have Instant-Mesh set up). To make viewing easier, I turned on a switch that sclices out only a small part of the arena for editing and increased the voxel-size so that loading only takes 15 seconds instead of half an hour. :D
Cheers,
Martin
ARENAWRANGLE_TOODFORCE.zip
Edited by tortoise
Added a pic!
  • Like 5
