stass3d
Memory Problem On Dop Simulation
There could be many reasons. However, if you're using an ATI video card, it's because there is a memory leak upon every redraw in the driver.
Share this post
Link to post
Which driver? If you're running an 8X.XX series video driver, you better have HyperThreading turned off. If you want to keep HyperThreading turned on, then you will need to go back to an 7X.XX series video driver.
If that doesn't work, do you have have a hip file that demonstrates the problem?
Share this post
Link to post
23640[/snapback]
We have still memory allocation errors here on our side. HT is disabled and we're using FX 3400 PCIe cards with driver version 81.67. We never managed to simulate more than 100 frames in one go. This problem has really something to do with the graphic card?
Share this post
Link to post
Actually I also have the problem of "memory allocation error" (and subsequent houdini crash) when caching in SOP, and often in COPs ... is there a way to make houdini just tells you "hey dude!.. i'm on 32bit platform.. so i cant use further memory" instead of just crashing?
cheers.
Share this post
Link to post
Deactivating the "Cache Simulation" option in the dopnet operator seems to fix the memory allocation crash, at least for the moment.
However, I think Houdini should be capable to cache some hundred frames RBD.
Share this post
Link to post
If anyone on this thread could post a hip file (and describe the steps required to duplicate the crash), that would go a long way towards helping us figure out what is going wrong...
Thanks,
Mark
Share this post
Link to post
Thanks,
Mark
23820[/snapback]
As soon as I have time I will strip down a demo scene for reproduction this week because the actual scene contains confidential material.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
