FLIP Render Flicker
Hello!
I'm trying to render a flip simulation and I'm getting a lot of flickering. They're all caused by my direct lighting, but decreasing the intensity still doesn't fix it. I've tried to change the sample rate and the rendering limits but I can't find a problem to fix the issue (noise is not a problem but the white reflections). I attached an image with the result.
Thank you in advance!
  • 10 months later...
