Sign in to follow this
konstantin magnus
Array values to points
While trying to create a point attribute based on array values from second input, I was expecting this to work:
v@Cd = v[]@opinput1_colors[@ptnum]; // only works on point 0
I also tried getcomp(), but it seems I am missing something.
vector a = getcomp(v[]@opinput1_colors, @ptnum); // uses first array value on all points
addpointattrib(0, "Cd", a);
camera_to_screen.hiplc
Edited by konstantin magnus
Here is an simplified example
Share this post
Link to post
im not familiar with @opinput1_"variable" syntax, but it seems like i points to the same pointnumber as itself. So since you only have one point i input number two, the only point that finds anything is point number one on your mesh.
I dont know the endgoal here, but if you want to access the "colors" array on point 0 on all your points, you can write it like this.
vector array[] = point(1,"colors",0);
@Cd = array[@ptnum];
Share this post
Link to post
Yes. I found for myself that the key F1 is most useful  key when you learn some soft.
And one tip, in case if you didn't know that yet. If you put cursor at function's name in wrangle and press F1 then pop-up Help Browser with help for this function. It works for expressions in Edit Expression window also. Very helpful sometimes.
Share this post
Link to post
Well, I usually read the documentation where needed. But I ignored the attribwrangle page thinking everything is done inside VEX code.
I dont find the idea of setting "invisible" match attributes particularly elegant, either, as they dont show up in the code. But it seems to be the most straight forward way to access arrays fro other nodes in Houdini, so thank you again for the hint!
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
