Hi
How do I save out all geometry information to a python numpy .npy file. I'm dabbling with a neural network that takes in a bunch of objs and spits out its so called interpretation..... But as yet I am working with just the points and not the vertices and prim information. How could I save all this information to an array so I could then reload the array back into houdini for houdini to display prims/vertices etc......
Thanks for your help
Edited by Bakiki
Share this post
Link to post
4 hours ago, Bakiki said:
Hi
I am not an expert but I would store info in different .txt files : a first one with all the points and their coordinates (each line with the point number, 3 coordinates, separeted by coma or else), a second one where lines contains prim number and its vertices numbers, and finally a third one with the coresspondance between vertices and points number.
Then, using dictionnaries, you could rebuild the points, and recreates the primitives using hou.Geometry creation methods.
http://www.sidefx.com/docs/houdini/hom/hou/Geometry.html
Hope that helps
Edited by StepbyStepVFX
Share this post
Link to post
Yes your suggestion sound logically but I was hoping to see some example code. I found code that represents a geometry construction but I would like to see one that deconstructs geometry into arrays... I will keep searching.
Many thanks for your suggestion..
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
