Polywire shape adjustments
bratro
Hi there!
I'm trying to add a certain shape to an object. (see image which hopefully explains it better ;-) the effect I'm trying to achieve is that the polywire should be bigger to the point and smaller/thinner in between. I did try it with a ramp but it obviously doesn't work. I'm still new to houdini and any help is very much appreciated!
Thanks
curve on object.hipnc
Trying to substitute Foor Loop with a primitive wrangle in @Atom setup. It works only for the first primitive.
I thought wrangle is a loop, e.g. the code inside VEX expression window should be executed for each primitive (at the same time, in parallel) but probably I miss something.
There should be printf() instead of sprintf()
ap_curve on object.hipnc
Edited by kiryha
You have to setup your foreach to also ouput index.
"currentPoint" will give you the pointnumber globaly. What your interested in is the index of the number in your current primitive.
foreach(int index;int currentPoint;primpts){
	float ramp = fit(index,0,len(primpts)-1,0,1);
Yes, that's works! Thanks, Thomas!
i[]@primPts = primpoints(0, @primnum);
foreach (int i; int currentPoint; @primPts){
    float ramp_index = fit(i, 0, len(@primPts)-1, 0,1);
    f@widthPrim = chramp("shape", ramp_index)/20;
    setpointattrib(0, "width", currentPoint, @widthPrim, "set");
scalePolywire_loop.hipnc
Edited by kiryha
  • Thanks 1
Thanks, Thomas! The file is working fine, I just wish to clearly understand how it's working in-depth and replicate it by myself.
I examine the point animation along curve part (skipping orientations) and have some questions and probably I will have even more questions later, so yes, when you will have time you can check that topic.
