printf
bonassus
I'm confused about printf. I don't know c++ and so never had to use it before leaning vex. I'm wondering about all letters you can use for the arguments in the printf function. I've seen %f used for a float. %d also used for float (decimal i guess), %s for string, and %i for integer.
the docs state: The conversion of the argument is specified by a single letter: g, f, s, d, x, c, p.
it goes on to show:
%g, %p, %c
Print an integer float, vector, vector4, matrix3, matrix or string in "general" form.
%f, %e, %E
Print a float, vector, vector4, matrix3 or matrix in floating point form.
The first example shows 3 argument types and 7 data types. Does this mean i can use any of the listed %letter arguments with any of the data types shown?
generally yes ;), %d will work with most "number" types same as %f, the difference between them is mostly formatting I think.
For instance with %d, it will limit the amount of decimals in the output string, whereas %f will try to keep as many digits behind the decimal point as possible.
There are some other tricks that you could use, such as %02d. that will pad the start of the output with zeros, so you can do a more easy alpha-numeric search for example :)
personally, I never had to use anything other than %f, %d or %s.
Edited by acey195
gramarz
  • Like 2
