POLYEXTRUDE BY ATTRIBUTE
doubt if ppl would be happy if you don't give them the csv.
Anyway, this bit here:
float H1max = detail(0, "H1max");
float fit0 = fit(@OldH1, 0 , H1max, 0, 1);
float fit1 = fit(@OldH1, 0 , H1max, 1, 0);
@Cd = set(fit0,0,fit1);
should Cd be P1 ?......so that you can use it later ?....otherwise, since you wiped out P1 in the promote....how's the extrude gonna work ?
