Resample_bias?
3__
another quick question:
Is it possible to resample a curve with a bias?
I'd like to do something like this:
Draw a curve, resample with ## maximum segments,
append a point sop and make Cd: sin($PT / ($NPT / 180)), 0, 0
Then resample the curve again using $CR as a bias,
with more points being added where $CR is highest.
scatter seems to be the most likely solution but it
doesn't seem to like $CR as an attribute.
-cpb
Tried POPs? Pass the curve in to a Source POP. In the Birth folder use Impulse activation set to $FF==1 and set your Impulse Birth Rate.
For the Birth Probability try something like:
$CR*0.3 $CR*1
To skew the waiting, adust the multipliers.
To help rebuild the curve, I created ptnum and stuffed in $PT then used this to sort then add to rebuild curve.
Hacky but not too bad.
I wonder why the Distribution Attribute in the Source folder of the Source POP doesn't quite work for Edges (attribute) on curves. Perhaps it needs a surface.
  • 2 weeks later...
