.geo Import For Lw
eetu
Here's a test version of a minimal .geo importer for Lightwave, http://undo.fi/houdini/lw-geo/
It understands an ascii .geo with polygons & point attributes only, behaviour with a .geo with other elements unknown.
In the general case I strongly recommend using .obj, but this importer reads in Houdini point attributes and converts them into their LW counterparts;
1-dimensional attributes are read in as weight maps
2-dimensional attributes are read in as uv-maps
3-dimensional attributes are read in as morph maps by default
3-dimensional attributes with a name starting with 'uv' are truncated to 2 dimensions and read in as uv maps
3-dimensional attributes with a name starting with 'morph' or 'v' are read in as morph maps (redundant, I know, but I might change the default)
3-dimensional attributes with a name starting with 'Cd' are read in as RGB color maps
4-dimensional attributes are read in as RGBA color maps
My original use was to get velocity vectors in as morph maps so I could render object sequences with motionblur, but
the attributes can probably be used for quite a lot of other reasons.
This hasn't been tested in production, so proceed with caution..
eetu.
  • 4 weeks later...
  • 4 weeks later...
  • 6 years later...
Ohh, a blast from the past :)
I think fluids was the original use case for this. I haven't tested this in years, but one obvious issue to know is that the plugin expects 'old-style' .geo files - you can still create them from Houdini by specifying a .hclassic filename extension.
hey, cool... ^_^
so it will create motion blur in LW alla the realflow method... right... ?
Netvudu
By the way, I'm just trying to export points (particles). Dunno if this makes a difference or not.
it might, it's probably better to try to export true geometry first as a test
Edited by erikals
