  2. Dynamic Particles - Houdini Rig needed
  3. SVGIcons.cache file corrupted
  5. My SVGIcons.cache file became corrupt anyone can share an un-corrupted version of this file ?
  6. Doxia Studio's Tutorials
    @DoxiaStudio Peace & Love
  7. Project points on geo
  8. Doxia Studio's Tutorials
  9. animate normal like sea ​​urchin
    His nickname is Toadstorm lol
  10. More Particles Following a PATH!
  11. Now it works fine , thank you.
  12. //set a wrangle to run over primitives int primpts[] = primpoints(0,@primnum); removepoint(0,primpts[0]); removepoint(0,primpts[-1]);
  13. Dam! no reply on that topic : / I'm looking into PFtrack atm too... Trevor, have you used it with Houdini ?
  14. Noise on ramp transition (edge)
  15. Modeling questions (remesh, polyfill)
  16. Rendering Cola
  17. Hello everyone, I am working with volumetric capture data and would like to have points scattered on it that moves with the data but also doesn't chang every frame. The issue is that the geometry, primitive number and uv's keep changing every frame. So I can't do the same trick I can do with mocap data using the primuv attributes. Anyone have any experience with this and how I should handle it?
  18. animate normal like sea ​​urchin
    Thank you illusionist!!!!
  19. Simple RBD hanging
  20. Hi Masoud, padzero() expression wrapped around the clamp() adds those zeroes: $HIP/tex/Display_A_`padzero(4,clamp($F,1,130))`.jpg https://www.sidefx.com/docs/houdini/expressions/padzero.html
  21. How to select a bevelled edges?
    Submitted an RFE for this
  22. Rendering Cola
  23. you may want to lower resize_container/Bounds/Field/FieldCutoff
  24. Building a beast Houdini + Redshift mainly
  25. export texture
  26. snapping point to a Null
