  2. Thoughts on this laptop build?
  4. Hello ! I have a custom ground and I want my object to not move until I have a collision. I connect my ground with my object by a Glue constraint. But so far my object is still moving... Do you have an idea ? Here you can see my simulated object, my red drawing is where I would like my object to be. ODForce_GroundCollision_001.hipnc
  5. Bullet Impacts
  6. Upon further investigating, this came up. Hmmm, will Email support with this issue.
  7. Got home tonight excited to work on some Houdini stuff, did a few tests and hit [Render] in render view tab. Render never started with a blue progress bar up top and a message saying: Generating Scene ..... Restarted computer and started a fresh Houdini Scene, dropped in a Test Pig Head and hit render again. Same thing! What's going on?! PS. Indie License if that helps! Please assist!
  8. Vex help
  9. Vex help
  10. Vex help
  11. Stretch UI
  12. Hi there, First time posting here . I am working on my final bullet destruction project for school and I was wondering if there was a way to constrain window glass, for example, to already cached pieces. I am trying to do layered destruction, where I first do the concrete layer then read those into a glass simulation where the glass is constrained to and collides with the concrete cache, and so on. I was told it was possible to do this as follows: "You can unpack pieces of your original sim near your windows and then use a Point Deform SOP to bind your packed window pieces to them! As usual, set them to i@active = 0 and i@animated = 1 until you're ready to have their own secondary simulation take them over. You can add all of your preliminary simulation in as a collider too in the same manner" The problem is I am not that familiar with the Point Deform SOP and don't know where to start with it. I have Googled around and haven't found much regarding this topic. I had previous experience with Thinking Particles and this method using cached layers was common. Thanks in advance for any insights. I have attached my hip file in case you want to take a look. Thanks D layered_destruction.hiplc
  13. Yesterday
  14. Od Studios launch
  15. Abstract in Houdini - Course
    Glad you liked it!:D
  16. Stretch UI
  17. Euler to orient-matrix inside dops.
    its done
  18. Run script in Command Line tools with Python
  19. Abstract in Houdini - Course
  20. meshing fractals
  21. There's ways to decompose/describe a vector - 3 coordinates (xyz) that scale the coordinate system unit vectors (ijk) and add them together: P = i*x + j*y + k*z. - direction (vector scaled to length 1) and legth/magnitude (distance from tail to head of the vector) - direction (two angles) and length And more... It's all about using the representation that is more sensible to the operation you are doing. For angular related calcs direction is handy, while for position calcs you want to deal with xyz, etc.
  22. If a vector also has a length, why is it perceived to be of 3 values?
  23. If a vector also has a length, why is it perceived to be of 3 values?
  24. Nature fun
  25. length = square root of (x^2 + y^2 + z^2) direction = normalize (x,y,z) [puts that point on the surface of a unit sphere] https://www.3dgep.com/3d-math-primer-for-game-programmers-vector-operations/ You should check out dot and cross product too: https://betterexplained.com/articles/cross-product/
  26. hi, I am testing vellum, and have a question. When testGeo is coming up from ground, all vellum particles are influenced and pushed away. Also, when he hit ground with hummer and lift it up, particles looks being sucked into holes made by hummer. However, these particle reaction should not reach such far away distance. I'd like to know how to control the influence distance. So far, I am thinking of solutions: 1 - reduce constraint iteration, 2 - make a space between particles at emission/creation times. 3 - add more friction, increase particle separate / highres- sim, etc. This result could be ok for sand FX, but when making snow ground, this won't work. Particles should be very rigid, and particle only moves around testGeo's feet and hummer. If anyone knows how to control it properly, let me know thanks!!
  27. SOP_PointWave example questions ....
  28. Abstract in Houdini - Course
