Access Detail Attribute In An Expression
GlennimusPrime started following Access Detail Attribute In An Expression
It's possible to add some type of noise with vops?
Hi guys, I want the background image be visible in the object's refraction, so I add my desired image to a "Background Plate" LOP, and to my camera background Image file tab too, but it doesn't work! How can I fix it? Thanks for helping.
- refraction
- background
how to create this curly advected lines
djehsan89 replied to djehsan89's topic in General Houdini Questions
Thanks Hannes. -
I guess what I see are errors as well. They are annoying, but generally don't impact my workflow. Here's what I see every time I put down a Karma ROP in the /out context.
