Access Detail Attribute In An Expression
Backticks are only needed when working with a string expression? OK got it thanks! I removed the backticks and now it seems to work ok. i@start_frame = chi("start_frame"); i@end_frame = chi("end_frame"); Then using this on the Carve SOP: fit($FF,detail(0,"start_frame",0),detail(0,"end_frame",0),0,1) Here's the updated .hip file if anyone needs it. carve_read_detail_attribute_v3.hiplc - Today
GlennimusPrime started following Access Detail Attribute In An Expression
It's possible to add some type of noise with vops?
Hi guys, I want the background image be visible in the object's refraction, so I add my desired image to a "Background Plate" LOP, and to my camera background Image file tab too, but it doesn't work! How can I fix it? Thanks for helping.
- refraction
- background
how to create this curly advected lines
djehsan89 replied to djehsan89's topic in General Houdini Questions
Thanks Hannes.
