  3. To get a unique animation per instance from sops, you'll have to unpack the geometry. If you don't want to do this, you'll have to use a custom vertex shader, which is definitely not simple. Either way, the way I'd do this would be to generate some sort of stiffness attribute on the geometry, and then use that as a multiplier for some flow noise in vops.
  4. Transform packed fragments at render time
  5. OCIO Darker viewport
  6. Direct Modeling HDA
  7. it's just the viewport limit displaying your volume as lower resolution turn it off and all your approaches will display correctly
  8. Color Twisting
  9. if connect adjacent points provides good enough outline for your pointcloud then you can as well just use Triangulate 2D + Divide SOP to get exact outline, which will even match outline points nr_foot_outline_alt.hiplc
  10. Hi guys, I would like to twist my geometry color while keeping the point position intact, so it will look like a paint spill kind of effects, how would I able to achieve it? Thanks. colorTwist.hip
  11. Align object with a transformed version of itself
    not aware of such list, but it's not all black and white, once you know what each node does, it becomes more obvious what you can combine with what depending on result you are after like your mentioned Bounds + Match Size can very well be Bounds + Transform By Attrib as that's what you are actually using in that mode
  12. Normal Map
    Hey, ist quite some time ago I used Mantra to do some Rendering but for a Project I'm working on atm I like the more realistic look it gives me compared to redshift. So with redshift I'm just plugging in a normal map and it renders just fine. Trying to do the same with a classic shader but I just get a corrupted Image. Cant see any place to manually plug in Utan and vtan. Something I'm missing?
  13. OCIO Darker viewport
    I've just configured OCIO to work with Houdini 17.5 and renderman and my viewport became very dark Instead of changing gamma is there a lut available somewhere to handle wiewport display under ocio ? or another way ? Thx
  14. Flip Fluids with Color
    Hi guys, I need the solution too, have anyone figure it out? Emitting flip with different color.
  15. Pro tips for flip meshing?
    One way to make better use of the particles that you already have, is to increase the Surface Oversampling of the reseeding. It defaults to 1.5, but I typically raise it up to 5-9, or even higher (24-36). This will spread out the particles, that are contained within each voxel. From the look I see in your video, you do have the Influence and Drop scale set very close to one another. Try widening the gab between those two values.
  16. Hi I've confused about converting polygon to VDB. Suppose we have about 100 geometry and we want to convert them to VDB fog, there is a huge difference in quality if you convert them directly or one by one with a loop. Direct : With loop : Another problem comes up when I want to flatten all the VDBs that come from the loop, I miss the details and the result is the same as the direct convert. Flatten VDB : I've attached the .hip file, hope anybody can help me. vdbCombine.hip
  17. Viewport bounding box
    Tha't it! Thanks
  18. Direct Modeling HDA
  19. Hello! I am currently instancing a few hundred bushes from speedtree. I am wondering, what would be a "simple" way to animate the instances in a small manor? Lets stay I just want the bushes to sway back and forth with some kind of noise added. Anyone have any ideas? The animation would be per instance so I dont want to deform the instance. I only want to move the whole object in a "logical" manner.
  20. Split an object using points and normals
  21. Pro tips for flip meshing?
  22. Align object with a transformed version of itself
  23. Had the pleasure to meet him in person a few times, great person! For me whenever old school people get back into houdini (or when people look at outdated tutorials) and need to understand "stamping" I always point them to the following video: "Geometry Workflows in Houdini 16 // Jeff Wagner // Illume Webinar"
  24. I think I found a way: https://www.sidefx.com/forum/topic/61608/
  25. Hi all, I'm writing a little python script to change some geometry values and it's working only if I declare the parameter name. hou.node("../subnet1/").parm("L_ear_shape01") But since I've about 20 custom parameters (could be more), to be passed to a function, the current parameter should be returned as soon as I change it's value, either by sliding the slider or roll the mouse button over it's text field. If there is anything like this it would be great: hou.node("../subnet1/").parm( #CURRENTLY_MANIPULATED_PARAMETER# ) I tried the following code at the very top of the script, but it returned None once. hou.evaluatingParm Is there away to get which parameter is being manipulated?
  26. embed external file in hip file
    yeah it depends. to me it feels lenghty (and clumsy), especially if there is a one click corresponding function with sop nodes (lock flag). but anyways personally I dont remember ever running into a situation where i needed to embed a picture... P. S. of course i realize I'm just spoiled ungrateful freak and that it's great you can do it with hda
