3delight shaders in houdini
- 188 replies
- sacredgeometry
- guilloche
- (and 4 more)
@Thoi I see what mean and asking , that was only One thing that I learn how to pull Old Stuff From users on GitHub , in Time those Files that someone Share become somehow invisible over period( or user mark those like somthing) of Time and with "Git program for windows" you can if Possible take those files ..seen some users asking on Github for Sharing those particular files @vinyvince . I need only files to Build Library
- 188 replies
- sacredgeometry
- guilloche
- (and 4 more)
