  2. Sorry my bad, I am not the best at explaining what issues I am having. I added a hip file that mostly shows how my setup is made. I am instancing hundreds of trees and I figured that instancing the branches and set of leaves per branch would make sense. I forgot to mention that I pack both the branches and leaves together for animation purposes. After the animation I use a unpack sop and I am then left with the branch instances and leaf instances separated. I will try using stylesheets and see if I can get something going
  3. Linux subprocess question
  4. Vimeo Profile is Online :)
  6. Material Builder to Layer
  7. Errors while rendering
  8. hi, 1. if you post a hipfile demonstrating the issue it will be easier to help you. 2. do you have any special reason to pack things in a way you do? i mean, having multiple packed levels isn't typically a great idea. can you pack leaves and branches separately? alongside that, unless your branches are duplicate geometries, there is no benefit from packing them. 3. materials should work fine if assigned on primitive level before packing. if you need to assign them after packing use material stylesheets, or Packed Edit SOP (simpler but doesn't offer that much)
  9. VDB From Primitive
  10. Visual Effects Artists Needed - Work Remotely
  11. Errors while rendering
  12. Linux subprocess question
  13. Hey! I'm in a situation where I have cached a huge amount of points on disk and I want to render those points. What I do in the scene is reading the bgeo.sc caches, merge them all together, trail the points to calculate velocity, apply a pscale, assign a shader and render. If I run it on the farm with IFDs it takes a lot of time to generate the IFDs for render, and I'm trying to reduce the time of this task. I noticed that the IFD itself is tiny, the big part is that under the IFD folder there's a storage folder where basically I have a huge bgeo.sc file per frame which I suppose is the geometry I'm about to render. I wonder if all of this is not redundant since all those operation can be done at rendertime I suppose...I tried to set the file sop in "packed disk primitive" but it seems I cannot apply pscale after that, all the points render at pscale 1...
  14. Hi! I am creating a digital asset with some paint nodes inside. I am promoting their interfaces to the hda UI. I have set the parameter in Type properties/Node/Default State to paint. This way when I click on the show handle brush it switches to the paint tool (in the bar above the viewport). The problem is that the brush circle doesn't appear and when I try to paint on the mesh it does nothing. I just found this thread about the topic but I haven't been able to make it work, maybe because a lot of things are changed from 2010. Any ideas on how to do it?
  15. Discretize 2d shapes
  16. Discretize 2d shapes
  17. parameter value relative offset
    THIS.... is fantastic! Many thanks, as an ex Softie it's super helpful to be able to do this (easily) again. Rich.
  18. Drag&Drop Contents
    hello could you give a hand into making this pipeable ? as in keeping it on a server and having it served via houdini.env ? Not sure about the folder structure/ PYTHONPATH etc I'm trying to keep things clean but not super familiar with the whole pipe'
  19. Greetings! I have a branch that I have scattered instances of leaves on. So a branch consists of about 20 points of leaves. I pack the leaves. I then pack the branch with the leaves before I copy the branch(now with the leaves packed with it) onto the tree. Now I get about 1000 branches with 1000 sets of leaves. I have made a leaf material that works good if each leaf is its own instance/point. However in this case where one instance of leaves consists of 20 leaves/points I get weird results. How would I go about to assign my material so it effect each primitive instead of set of points? treeTeststuff.hip
  20. VDB From Primitive
    Instead of using spheres, you could just replace each sphere with a point at it's centre and assign it a pscale attribute which is the radius of the sphere. Then you can use vdbfromparticles and get a perfect sphere for each one.
  21. animate normal like sea ​​urchin
    sorry for the mistake...
  22. Hi, A simple question but I can't seem to get the answer. I need to convert a sphere primitive to a volume, when I do this with a VDBfromPoly instead of the VDB showing up as a perfect sphere I get this low res sphere similar to what you would get with a low frequency poly sphere (see screenshot) Is there something to tweak to get a perfect sphere, or is there a better way to to convert from a primitive straight to a volume? P.S. The reason I need to do this is because Im copying a few hundred thousand spheres to points and if I try to do this with poly spheres houdini crashes always.. only way I seem to be able to do it is by keeping the original sphere a primitive. Thanks!
  23. Errors while rendering
    I use houdini 17 and while I'm rendering with mantra with default render settings Error occurs Houdini console shows " OpenCL Exception: clFinish (-36) OpenCL Context error: CL_OUT_OF_RESOURCES error executing CL_COMMAND_READ_BUFFER on GeForce GTX 1060 3GB (Device 0). OpenCL Exception: clEnqueueReadBuffer (-5) OpenCL Exception: clEnqueueReadBuffer (-5) OpenCL Context error: CL_OUT_OF_RESOURCES error executing CL_COMMAND_READ_BUFFER on GeForce GTX 1060 3GB (Device 0). OpenCL Context error: CL_MEM_OBJECT_ALLOCATION_FAILURE error executing CL_COMMAND_WRITE_BUFFER on GeForce GTX 1060 3GB (Device 0). OpenCL Exception: clEnqueueWriteBuffer (-4) " Any suggestion, please?
  24. Thanks! I got what i want to do!
  25. Hello! I was going to ask how to do this but I figured it out and so I might as well post this in case someone else has the same problem. If you want to source expansion for pyro in houdini 17, we don't have the fluid source node. Instead we have the pyro source. However, there is no expansion option for initialize. I remembered there was a shelf tool that auto-creates the nodes, so I tried it out. As it turns out (and seems confusing to me) you have to use the flip source then choose expand. Back in Dops you can use the volume source node and set it to expand also. Anyway, hope this helps-
  26. Yesterday
  27. Rendering Cola
    Here's my try at it. I reversed the faces of the bubbles, then merge them with the main/outer fluid mesh. cola.hipnc
  28. Contract A Rope (Vellum)
    animating restlength is the way to go, but you can't animate it in SOPs as that will not be reflected in DOPs so you either animate Rest Length Scale using Vellum Constraint Property DOP or if it's not just curve (rope), but actual ribbon band like in the video then you can use Vellum Rest Blend DOP to blend towards shrunken version, that will update rest lengths accordingly and result in contracting
