If the point number per prim is different, you can workaround it by resampling all primitives with same count. After this you can capture each point from the original curve using xyzdist() and reorder the vertices based on their u-param. It may be a bit less accurate. align_curve_starts_modA.hipnc - Today
mehndidesign joined the community
appreciate you.
thank you so much
Nick_OA joined the community
Namended joined the community
- copytopoints
- copytopoints
Any ideas? -
