bkfuege joined the community
Hi Luke, is this position exclusive for US citizens? -
Looking sweet!, would you please share a breakdown of the process a bit more? I am working on a similar scene, and I'm struggling to get the proper shader effect for the snow and I want to render with Karma XPU and CPU Your snow and specular is looking great. I'll greatly appreciate it.
