  2. Copy from a random Seed
    Well I found the solution ! I've just created a second point wrangle after my loop and linked the seed of my new PW on the old PW (the one in the loop) and then randomize the seed of the new...
  3. Run Python with system environment variables
    you could use import sys sys.path.append(path to you python site packages) to use all installed modules. If that is your goal?
  4. Greetings! I am currently creating a digital asset in which I want to be able to create x amount of folders with the exact same options. The thing that differs is the source file path for each folder, but the same settings/options will apply. My question is; How do I keep the references of the inputs in each folder so it corresponds to the same index of the folder? If that makes sense..
  5. SDF from density in Dops
    Maybe the master himself? @Pazuzu
  6. SDF from density in Dops
  7. Best/Fast approach for car wreck look (no sim needed)?
  8. Hello! Maybe you can try with manual sculpting of the damaged parts and then add on top the noise (I think I would go with worley and antialiased). You can also get extra details with the shader and painting cracks. Doing a real simulation would be cool but between geometry preparation and setting up the simulation, you risk to lose a lot of time.
  9. Today
  10. Hi; In uv-fllaten what are pink islands? Thanks.
  11. Ring pyro burst
  12. Ring pyro burst
  13. Its missing because you dont have the 'v' attribute on the incoming geometry.
  14. Ring pyro burst
  15. Trying to set up a simple VDB collision with rotating 'fan' geometry. My issue is I am missing point velocity in my VDBFromPolygons SOP. No point.v available under Surface Attributes. What is the simplest way to resolve this? collision_VDB_missingVelocity.hiplc
  16. I wrote an article that is probably only of interest for the .1% It is a crash introduction to HDK, C++ and the mesh laplacian. https://mbaadsgaard.com/portfolio/laplacian-eigenvector-plugin-for-houdini/ Feedback is, of course, also welcome
  17. popdrag - slower particle in selected radius
  18. All the powerfull and magic of houdini, few line written to do what other software will do with addon or more hassle, and with less flexibility. If you are confused and intimidate but these vex lines, i could tell you that if you start learning houdini in a proper way from the base, this will look totally natural to you very quickly in fact
  19. I prefer to achieve this through mantra,I made some attempts,But external objects do not show the feeling of being illuminated internally.Do you have any good suggestions for this? If there is, then I will be very grateful.
  20. You seem to be everywhere, brother
  21. Yesterday
  22. Hello, I need to deform a car geometry to quickly create crash like deformation (plz, see attached). Note, I don't need a full simulation, just the final shape. What is the best approach? I tried to deform some parts of the car mesh using turbulence/anti-aliased/mountain noise, but it did not look right! Another idea is to use vellum (or bullet with soft constraints) to simulate metals and hit the car by random objects, but I am hoping for something faster. Any ideas? Thanks,
  23. Hello everyone! I'm having problem with this Solver SOP, the Prev_Frame doesn't contain the attributes I modify in the solver, like it's always the first frame. Maybe I don't understand how this work but isn't the Prev_Frame node containing the output geo from previous frame? I idea here is to check if a point velocity is above a certain threshold then start a timer on it (decreasing each frame), these points are used as a smoke emitter. The original geo is a RBD sim, at first a thought is was that but even with a test sphere it doesn't work... Please help, thanks you! panda_dust.hipnc
  24. Hello, i have an issue with the copy stamp, I created a Point wrangle where I choose randomly pieces from black or red color in a loop (its a building), so i created a variable with a random in my copy stamp and i want to paste it in a seed I created in the point wrangle, in order to copy different seed of my object on point, it doesn't work at all, it's always the same copy of the same seed... Thank for any advice, cheers
  25. popdrag - slower particle in selected radius
