  2. How does align SOP work ?
    I keep on reading the doc and looking at the examples, but I don't understand this: "Aligns a group of primitives to each other or to an auxiliary input." The schematics is confusing to me, and so is documentation. What does it mean "align a primitive to [another] " ? Can someone provide an example of a non aligned group of primitives, and an aligned group of primitives ?
  4. Fully procedural, destruction ready building.
  5. Fully procedural, destruction ready building.
  6. Thanks for your quick reply Andrea! I’ll try it later today and post the result.
  7. Pro tips for flip meshing?
  8. Color Twisting
    Thats works! Thanks!!
  9. Ocean Spectrum Heigh Map
  10. Hello! First unpack your geometry before feeding it into vellum nodes, they see just one point. Second go inside the DOP network of the vellum solver. In the vellumsource change "Emission Type" from Only Once to Continuous, otherwise is going to take just the first frame. sphere_vellum_fix.hip
  11. Hello everyone! I'm trying to make a setup with spheres born in another sphere using vellum. So basically speaking, I have a Pop network shooting particles, then I feed it into a Copy to Points node and then to Vellum Configure. It works but the problem is that it takes only the first particle and ignore the others. I guess I need to update something inside vellum but can't figure out what's exactly. Can anyone take a look at the attached scene and point me out to possible solution, please? Thank you a lot in advance. sphere_vellum.hip
  12. Help[SOLVED]
    HELP Houdini 16. 0.504
  13. Genetic Algorithms in Houdini
  14. Hello everyone, Recently I tried to create a completely procedural building, which at the same time is ready to be destroyed with Houdini and this is what I ended up with. https://vimeo.com/355676432
  15. Direct Modeling HDA
  16. Sop vex ptnum vs cvex
  17. Yesterday
  18. as someone who has learned Hou in forums and looking at SideFX-s early videos , I am very thankful to your precious contribute ! i can even now hear your distinctive voice in my head now .. LOL ! thank you for your first 25 years Jeff !! .cheers
  19. Procedural OBJ splitting
  20. Sop vex ptnum vs cvex
  21. Ocean Spectrum Heigh Map
  22. To get a unique animation per instance from sops, you'll have to unpack the geometry. If you don't want to do this, you'll have to use a custom vertex shader, which is definitely not simple. Either way, the way I'd do this would be to generate some sort of stiffness attribute on the geometry, and then use that as a multiplier for some flow noise in vops.
  23. Transform packed fragments at render time
  24. OCIO Darker viewport
  25. Direct Modeling HDA
  26. it's just the viewport limit displaying your volume as lower resolution turn it off and all your approaches will display correctly
  27. Color Twisting
