  2. Hello; Please help : I need to move my geometry perpendicular to existing Normals. Thanks. CrossNormal_01.hip
  3. Packed Primitive transformation equation
  4. Packed Primitive transformation equation
  6. House fire sourcing Pyro
  7. Vellum leather belt
  8. VOP Keyword Reserved
  9. Vellum leather belt
  10. Hi, In Bullet simulation, pieces are packed and have attributes : (1) P , (2) orient quaternion, (3) pivot. Somehow, these three attributes compute the final transformation matrix for each piece. My goal is to animate these simulated pieces in reverse (not just playback in reverse, but instead create more "interesting" animation). My question is how are Pivot and P related? Initially, P equals Pivot, then as the simulation goes: Orientation changes (which is logical), and Pivot drifts away from P (i.e. not equal anymore). I checked bullet[T|R|S] are they are all zero or identity. Thanks,
  11. Yesterday
  12. Vellum leather belt
  13. Hi, I am following this tutorial, but I don't get a shadow matte with my toon shader. I am wondering why this is. If you want to take a look: shadowmattehip.hipnc (with the Links_Schaduw mantra node) I would also like to know how I could get an equivalent of the diffuse color image plane while Toon Shading. Is Toon Shading more limited in this regard or is it possible? (to have highly customisable composites) Thanks.
  14. Initial State with Vellum Grains
  15. Using the rayed and then volume-extruded grid in addition to bumping the substeps way up (5 min/10 max), using volume collisions and the RBD solver are doing the trick on my quick test mesh. Haven't tried it on the final big guy yet--I'm guessing more substeps will be in order.
  16. Mmmh. Just for clarification. While this isn't finished, it's close to the current needs. I create a "shadow" rig which resembles the final bone structure. I'm going to create this rig one by one afterwards, but if I need to change it's proportions, I want to alter the shadow rig and have some clever mumbo-jumbo apply this to the existing bone rig. Each "bone" does calculate it's restlength, position and orientation. it also carries it's name which is identical to the real bones name. This applies for the nulls, too. Does some script already exists which could be altered or is this new territory? Cheers!
  17. Hi there I made some snow with very small vellum grains What Im trying to achieve is to set an initial state when my snow is already relaxed (I am throwing a box made of grains in top of a mountain), and then to continue colliding with some objects. How can i make the simulation read the first frame and then start writing the next
  18. Vellum leather belt
    I'm trying to find a way to animate a metal belt buckle and have the leather strap follow the position whilst being effected by gravity/environment and still not intersect with the buckle itself. Essentially I'm looking to recreate the "rope knot" effect that everyone has seen recently but with a more irregular shape such as a belt (rectangular instead of round ) Is Vellum the best system to create something like this? any help would really be appreciated thanks everyone
  19. Hi there, I am trying to project a texture onto an UV unwrapped object through the projection camera and then bake the projected texture on the original object UVs. However, when I do it, the uvtexture node gives me new UVs used for projection than the original object UVs. I would appreciate any tips how can I bake it out on the original object UVs. I attached my setup in a file below. Many thanks for any tips! uvprojectionbake.hip
  20. A slightly more brutal approach could be using an Attribute Blur SOP on P and try slightly higher blur values. Or use a DeltaMush deformer, with some non-spiky object as reference object. If that won't help, is it possible the distance to the nearest points might be different for the spiky areas? You can check that easily using point clouds: (More on point clouds: http://www.tokeru.com/cgwiki/index.php?title=JoyOfVex20 )
  21. I'm sorry to say it, but this setup is a bad idea. I the initial fracture you have size differences but still you scatter 250 points on each piece resulting in insane small pieces. If you really want to do that put the fracturing after the for each network. But anyways the resulting shapes won't be nice and it will take very long to calculate. If you want just a convex decomposition 4 points should be enough.
  22. Thank you, that worked perfectly!
  23. Houdini 18 Wishlist
    Flipbook / Mplay: It should be able to create directories by its own while saving. Attribute Wrangle: Quick preview of necessary arguments while typing a function.
  24. From what I see in the images, your candidates also have a low density of points. Maybe you can run a Point Wrangle, then run a nearpoints() function to get the near points in a given volume around your point. Then you store on each point an attribute density = len(nearpoints())/(4/3Pi*power(radius,3)) delete points that have a density below a threshold. Play with the threshold until you identified most of problematic-spiky-lowrez area. And finish manually... should save you some time. Of course it is based on the assumption that your spikes are low point dentity areas... You could mix that as well with curvatures (selected areas that have high curvature AND low density of points ?). Last but not least, you could use a similar attribute that would be based on len(neighbours()) (eg. the number of points that share an edge with your point)==> if your spiky areas are less connected, as you mentionned, you’ll see that as well. and you can even delete based on these 3 attributes...
  25. EmberGen pyro real-time engine
    If they can show their pyro interacting with fluids or deforming geometry while spawning realistic sparks, then maybe people might start to feel a bit threatened. But the more features that are added, the slower things get. Directors often want things to look a certain way, so control is a pretty big thing to lose. But if they can offer all that, kudos to them. I just didn't see it in the video.
  26. packed geo confusion
    it's not true for all intrinsics for common ones like bounds, measured(area, perimeter, volume) it's probably true but definitely not for transform, pivot, unexpandedfilename, geometryid, viewportlod, ... and many others that you simply can't just derive from other data, they need to be stored and passed with the prim, like when you have class in programming, some getter functions return member variable values directly, but some will compute the values on the fly from others while you can't compute orientation from just a point, there are also no point intrinsics so it's not like Houdini can either, unless you extract it from transform intrinsics of attached primitive for example if it has it
